Rack and pinion opinion
Old Feb 20, 2008 | 10:06 AM
noboundaries6289's Avatar
Default Rack and pinion opinion
hey all, went to get my oil changed today and the tech said my driver side rack and pinion was leaking. He said it needed replacing which I found to cost $600-$1100 for everything. Can't I just use some stop leak in the power steering? or do I need to replace the whole unit? Thanks
Old Feb 23, 2008 | 11:20 AM
sir_nasty's Avatar
Default RE: Rack and pinion opinion
it's a high pressure system so stop leak wouldn't hold it and may clog some passages, if you can't replace the hose/fittings that are leaking you very well may need to replace the whole unit to correct the issue.
Old Mar 6, 2008 | 10:12 AM
Seeds's Avatar
Um yeah, replace the rack, when they start to leak it is because the seals are bad... stop leak would ruine the pump as well as not fix the issue. A new rack is about 500 after the core at any autoshop. You should go ahead and replace your tierod ends as well, there about 60 for each side, and it only takes a couple of hours to do your self.
Good luck
-Seeds
jay81
Jun 10, 2008 03:22 PM
liam71234
Oct 17, 2007 11:25 AM
liam71234
Oct 7, 2007 09:54 AM
1186gibriadams
May 27, 2007 09:12 PM
1186gibriadams
May 27, 2007 09:00 PM
