Rear anti-roll/ sway bar, tie bar
Old Jan 24, 2007 | 12:10 PM
rob3201's Avatar
Default RE: Rear anti-roll/ sway bar, tie bar
Did you but the acura sway bar from the net or directly from the dealer ? Would it void my warranty ?
Old Jan 24, 2007 | 01:17 PM
RTexasF's Avatar
Super Member
No warranty problems. I ordered mine online from an Acura dealer but I don't remember which one.
Old Jan 25, 2007 | 04:52 PM
rob3201's Avatar
For the 17mm, what year TL (6 spd) we talking about ? Im guessing 2004 +
For the 20mm what model and year we talking about ?
Thank you
Old Jan 26, 2007 | 12:48 AM
RTexasF's Avatar
Super Member
'03-05 I believe. The '06 & '07 may work but not positive about that.
17mm TL Swaybar Part Numbers (what you need to order if you want the 17mm):
Qty 1, 52300-SEP-A03, 17mm Stabilizer Spring (Sway Bar)
Qty 2, 52306-SEP-A02, Stabilizer Bushings (17mm)
Qty 2, 52308-S3M-A00, Holder
20mm TL Swaybar Part Numbers (what you need to order if you want the 20mm):
Qty 1, 52300-SEP-A11, 20mm Stabilizer Spring (Sway Bar)
Qty 2, 52306-SEP-A11, Stabilizer Bushings (20mm)
( Credit & Thanks to Conundrum on another forum.)
Old Jan 26, 2007 | 12:23 PM
rob3201's Avatar
Going for 20mm. I will post the results ASAP
Thank you all
Old Jan 26, 2007 | 04:23 PM
RTexasF's Avatar
Super Member
Cool!
[IMG]local://upfiles/127/D822CA2F31754A59BA4CAE5727F74423.jpg[/IMG]
Old Jan 28, 2007 | 05:57 PM
  #17
Peg_Leg's Avatar
i would also like to know if the tl rear sway bar will work on my 2006 accord vp thanks
Old Jan 28, 2007 | 09:59 PM
  #18
RTexasF's Avatar
Super Member
I don't think a VP has a rear sway bar or the links for one but I'm far from sure of that. Look under the car to see if it has one. If so you can upgrade easily, if not a little more work will be involved.
Old Jan 28, 2007 | 11:51 PM
  #19
Peg_Leg's Avatar
if it doesn't have one i guess i could see if i canorder the links or check a junk yard
Old Feb 3, 2007 | 01:39 PM
  #20
jancoka
