steering wheel shaking hard
Old Nov 22, 2007 | 01:07 AM
patrickr2018's Avatar
Default steering wheel shaking hard
hey guys. well when I brake my steering wheel shakes very hard. I know it's not the alignment cuz I already got one done and it started b4 that. Im thinking maybe the rotors. dunno? just thought I'd throw it out there
Old Nov 22, 2007 | 08:14 AM
BlkCurrantKord's Avatar
Default RE: steering wheel shaking hard
Rotors are warped
Old Nov 22, 2007 | 10:40 AM
klrspz's Avatar
that or you have the infamous break issue with accords...
but then again, you didn't post your year..
take the rotors to oreilly and get them machined/turned; should cost 10/rotor + tax.
Old Nov 22, 2007 | 11:10 AM
What infamous brake issue? Never once heard of anyone having "issues" with their brakes.
Old Nov 23, 2007 | 11:42 AM
klrspz's Avatar
Well a lot of manufacturers have problems with using cheap-o brakes in their systems, and tend to heat up quickly, leaving deposits on the rotors.
Many Honda and Acura owners have benefitted from switching from OEM brakes to aftermarket ceramic brakes, and have found that it will clean the rotors themselves since they are harder.
I've read about this on many honda forums, and people with acura's at work have told me the same thing with their cars... just thought it was pretty well known.
Then again, it could just be rumour.. I had this problem for sure, went and machined, and about 2 mo later it came back.. cahnged pads, and I'm good without new machining.
Old Dec 4, 2007 | 09:05 AM
Eworx
I have a 03 and changed to ceramic brakes.... thay are great
Old Dec 4, 2007 | 09:41 AM
falkore24's Avatar
but they don't fix the shaking issue!!!!! For pads, I recommend EBC Redstuff for spirited driving or yellow for mature driving. Or Hawk HPS ... I use them .... I've heard that HP's are better for spirited driving also, but I can't recommend what I don't have experiance with. Also, Raysbestos makes great ceramic pads too.
For rotors, I recommend Brembo blanks. At $40 each, how can you go wrong?!? I have their sport drilled setup.
Patrick: As mentioned, there's about an 85-90% chance that your rotors are shot. If resurfacing is possible and cheaper than the Brembos, that is an option, but I'd go with the new, better rotors.
Old Jan 26, 2008 | 11:29 AM
louofm1's Avatar
BlkCurrantKordis right .....warped rotors if shaking occurs only during braking
RomanianAlien17
Jan 8, 2014 11:23 AM
pimpp1184
Nov 5, 2009 03:32 PM
Itzomi
Jan 8, 2009 03:51 PM
will93
Aug 5, 2008 11:17 PM
