Strut Tower Brace for 6th Gen
Old Mar 18, 2007 | 01:22 PM
tkundert2's Avatar
Default Strut Tower Brace for 6th Gen
I have a 2000 EX w/ 4cyl, and have read in this forum about using a 6 cyl strut bar, or one from an Acura as a mild upgrade to chassis stiffness. I can't find this part on Honda or Acura estores; what do they call them, or what section are they in? I know what it is, and where it is on my car, but just can't locate in the electronic catalogs.
Or (even better) does anyone know the factory part numbers?
Thanks in advance.
Old Mar 18, 2007 | 03:28 PM
tkundert2's Avatar
Default RE: Strut Tower Brace for 6th Gen
Old Mar 18, 2007 | 10:24 PM
otsb708's Avatar
Almost A Senior Member
I would just go with an aftermarket bar, (ie.Neuspeed, DC Sports, countless other companies)that make bars for your car. I think it is just as expensive to get an aftermarket bar than to go with getting an Acura STOCK bar than anything else....
Old Mar 19, 2007 | 12:30 AM
tkundert2's Avatar
Thanks, I may do that and want to spend wisely.Anyone have any recommendations?I'm assuming thata factory V6 or Acura bar is definitely stiffer than the two small (stock) brackets I currently have, whereas at least some of the aftermarket ones might look pretty andbut not be much different than what I have.
Update: OK, I found the Acura part (74180-S0K-A00) in the Cross Beam section and is priced less than $50. I will go this route if someone can confirm this (for a 2000 Acura TL) will fit on my Honda.
**Any 6th gen owners done this? (installed Acura TL strut bar on Accord)
Old Mar 20, 2007 | 11:12 AM
tkundert2's Avatar
Old Mar 21, 2007 | 07:23 PM
tkundert2's Avatar
Found my answer here. http://www.honda-tech.com/zerothread/797528
Old Mar 21, 2007 | 07:34 PM
sir_nasty's Avatar
sorry I didn't catch this post sooner.... and the part you're looking for is more commonly refered to as a sway bar and it goes under the car, the diameter (measured in mm) determines the stiffness...
Old Mar 27, 2007 | 03:52 PM
tkundert2's Avatar
No, I was looking for the bar that connects the shock towers. I couldn't find the Acura p/n's or pics on the dealer parts sitebut finally did so will go that route. Thanks.
ORIGINAL: sir_nasty
jjmaccord
Jan 19, 2011 10:03 PM
Rippen Griffin
Jul 25, 2010 02:19 AM
ducatiff
May 15, 2007 07:39 PM
bigdog1428
Dec 19, 2006 09:07 AM
Zambo
Jan 30, 2006 05:50 AM
