Too much spring compression
Old Nov 13, 2010 | 12:39 AM
sanchdaniel's Avatar
Default Too much spring compression
I reinstalled my eibach sport lines on some new koni yellows. My question is, Why do the springs compress so much, are they too old? I can't even get a finger through the springs.
Old Nov 14, 2010 | 05:47 PM
clutch811's Avatar
well theres two main types of springs, constant rate and progressive rate. constants stay...well constant and progressives change as the driving gets more aggressive. the progressive springs are usually grouped very close together in spots to allow this to happen. also just so you know even on constant rate springs there will be very little room between each coil depending on the drop. sportlines drop a lot so i can see them being tight together. Im sure they are fine.
One Legged Eagle
May 10, 2014 12:37 PM
RobinsonRicer
Dec 22, 2013 08:42 AM
Sadus
Sep 6, 2011 11:29 PM
NICK63
Nov 2, 2009 11:57 AM
el toro
Nov 1, 2006 09:20 PM
