Vibration
Old Jun 20, 2014 | 03:46 PM
dirt's Avatar
Default Vibration
I have a 2004 Accord EX with an automatic and 125K miles. My friend hit a parking curb in a parking lot at about 5 mph. On the passenger side. Now the car vibrates at 60 mph and continues to vibrate up to 70 mph then the car smooths out. I've since replaced all four tires and had them balanced twice. Also the right CV axle was replaced and it seems to be worse. I looked at both motor mounts and they look OK and there is no excessive movement of the engine. I also experience vibration under hard quick acceleration. Any suggestions? Thanks in advance.
Old Jun 20, 2014 | 05:30 PM
You may have bent the rim slightly. This might produce an out-of-roundness that would cause vibration.
CV axles can produce vibraion under acceleration. I had that on my 94 EX and req'd high quality Raxles to fix.
Old Jun 20, 2014 | 05:49 PM
dirt's Avatar
Also, if I let off the accelerator pedal while traveling at 60 mph the vibration stops.
Old Jun 20, 2014 | 05:50 PM
dirt's Avatar
I thought the same thing TexasHonda maybe a bent rim. Thanks
Old Jun 22, 2014 | 08:56 PM
When it goes away with letting off the accelerator, the first thing I think of is axles. But you changed one of them. What about the other? What about poor quality new one?
Bent rim probably would vibrate regardless of accelerator. But a damaged belt in the tire might vibrate only when accelerating.
Old Jun 22, 2014 | 09:58 PM
dirt's Avatar
Monday morning I am going to swap the tires on the passenger side (front to rear rear to front) to see if that helps.
Old Jun 24, 2014 | 02:32 PM
Moving it to a different corner won't fix it, but you WILL narrow it down whether it's something in the rim & tire vs. brake/axle/hub...
nixalot
Mar 22, 2007 12:03 PM
JW
Feb 28, 2007 09:41 PM
vpd74
Jul 14, 2006 10:23 AM
Markus26
Apr 17, 2006 10:30 PM
janicesaccord
Mar 4, 2006 08:18 PM
