Vibration cb7 when speeding up. HELP!
Old Jan 29, 2013 | 03:05 PM
toniboicb7's Avatar
You were right after 3 different shops, they found the problem. I mave a bad tire, never thought that KUMO TIRES would let me down so I am now going to put on Yokohama tires. and will know if for sure was a bad tire.
Old Jan 29, 2013 | 07:44 PM
Hope the new tires are good for you.
But I'm curious now, you said it still have the vibration when you put on different wheels & tires? Maybe the other set has something simple like just being out-of-balance.
Old Jan 30, 2013 | 11:50 AM
I had a long term, pesistent vibration under hard acceleration on my 94 EX that was finally resolved when CV Axles were replaced (after two sets of rebuilt axles from Autozone) w/ Raxles.
I tried various methods of diagnosis of problem, but eventually had to replace the AZ rebuilt CV axles because I had ruled everything else out.
Old Jan 30, 2013 | 04:34 PM
toniboicb7's Avatar
so i got my new tires and problem solved. i had my stock tires checked for the heck of it. i had two tires out of balance and 1 with the same problem as my custom rims. bad tire, apparently it doesn't feel the same as a low profile tire to a regular tire. but I must also add that I did change my front rotors so the vibration when braking stopped. thanks a lot for the feedback in a you know I appreciate it. hope this help someone who are experiencing the same problems talked about hear, could cause vibrations. I must add don't buy cheap tires.
Reggi's-accord
Aug 10, 2012 07:21 PM
cb7sk8rdude
Sep 7, 2011 01:20 PM
AccordLXMaster
Jan 13, 2009 04:33 PM
thunder_x
Sep 10, 2007 08:56 PM
yosfynest11190
Mar 20, 2007 03:19 AM
