wanting to get rid of neuspeed springs....what to get
Old Jan 17, 2008 | 05:56 PM
isenegger's Avatar
Default RE: wanting to get rid of neuspeed springs....what to get
well just the back leans inward at the top. the ride is ok. i really dont think there is a camber kit on it at all. just some low springs. im just wondering what kind of springs, camber kit, and maybe struts to get. or i could go with a coilover kit if cheap enough. anyone got any good sites to order from. im just getting back into this import scene so any help would be appriciated!
Old Jan 18, 2008 | 08:40 AM
falkore24's Avatar
ORIGINAL: pyaarawala
So if the tires look like that from the rear and front, is that what's called "negative camber?"
I believe that is correct ...... I get the positive and negative confused.
ORIGINAL: isenegger
... or i could go with a coilover kit if cheap enough.
Don't go too cheap on your suspension. Do it right once and be happy with it. After all, a few weeks afterward, the extra few hundred dollars won't kill you ..... it'll just limit spending money for those few weeks, but you'll be enjoying driving instead of spending money other ways!!! IMO, a good setup cost about $1500-2000 including installation, alignment and chasis supports. You could knock off about $500 if you can install it all yourself.
Old Jan 18, 2008 | 06:28 PM
isenegger's Avatar
i wanted to know if coilovers do away with the struts?
Old Jan 18, 2008 | 06:38 PM
sir_nasty's Avatar
yes and no... you can never do away with the struts. however a high end adjustable coilover is going to replace the stock struts and replace them with aftermarket ones that are threaded. there are however coilover kits that simply contain a sleve that goes around the stock strut and has an adjustable perch that the spring sits on...
Old Jan 19, 2008 | 08:15 AM
isenegger's Avatar
well i decided to just keep the springs and i ordered a rear adjustable camber kit of ebay http://cgi.ebay.com/ebaymotors/ws/eB...07928&rd=1
gb95accord
Dec 19, 2012 02:26 PM
schizzy
Dec 17, 2008 08:22 PM
jipmpizzle
May 22, 2007 11:04 PM
YeuEmMaiMai
Sep 5, 2006 09:37 PM
houser995
Feb 17, 2006 10:56 PM
