What Keep the Rear Passanger Tire Straight.
Old Apr 12, 2007 | 01:17 PM
RoKnAzn's Avatar
Default What Keep the Rear Passanger Tire Straight.
Well, I was in a accident yesterday.. No one was hurt. The car hit the curb and went oover to the next lane. Now the Rear Passanger tire is no parallel with the car anymore. If u look at it behind the car. It is at 11 O'Clock. I have remove the Long Bolt that hold the Caster and Toe Arms. What do I need to replace to make it straight again..
Thanks
Anthony
Old Apr 12, 2007 | 01:53 PM
2.2ex965spd's Avatar
Default RE: What Keep the Rear Passanger Tire Straight.
It sounds like a control arm
Old Apr 12, 2007 | 04:40 PM
RoKnAzn's Avatar
Anything else? IDK, I think I might need to put in new wheel bearings too...[:@]
Old Apr 12, 2007 | 05:24 PM
I doubt the bearing is bad, give it the "wiggle test," grab top and bottom of tire, and front and rear of the tire. If the wheel don't shake, the ball joint and the bearing are good.If it is visually out of aligngment, it is probably a control arm though
Old Apr 12, 2007 | 06:01 PM
RoKnAzn's Avatar
I know I need new rear Rotors and Pads and etc......[:@]Any good replacement Control Arms? Not to Expensive...Has this Happen to anyone else?
Old Apr 12, 2007 | 06:20 PM
The cheapestway to go is tohit up the salvage yard or ebay
if your bent buyingnew stuffgo to www.hondaautomotiveparts.com they're a dealership out of Rhode Island I believe, it is often cheaper for me to go there than my local dealership, even after shippi
Old Apr 13, 2007 | 12:41 PM
RoKnAzn's Avatar
Is there any Cheap Ebay Specials Lower Rear Control Arms? That is good?
Old May 11, 2007 | 11:04 AM
RoKnAzn's Avatar
Well, I replaced the 2 Lower Control arms with new ones plus 2 new bolts. Its still not straight but it is better then before. What should I replace next?
Thanks
Anthony
Old May 16, 2007 | 01:46 PM
RoKnAzn's Avatar
Anyone?I need this car back up and running correctly..
Thanks
Anthony
sanchdaniel
Feb 5, 2011 06:59 PM
pandadesigns
May 26, 2009 11:49 AM
tru3_k177
Jan 11, 2008 01:18 PM
Calevra18
Sep 21, 2007 11:46 AM
RoXeTTeMaN
Aug 5, 2006 03:22 PM
