WHEEL ALIGNMENT ?
Old Aug 23, 2007 | 07:44 PM
Chaqui04's Avatar
Default WHEEL ALIGNMENT ?
I did a four wheel alignment on my car but know i've notice that thepassenger side of the car sit a lillte bit higher than the drivers side front and rear . Is it possible that the wrong alignment could mess up the ride hight? ( 2004 accord coupe ) .
Old Aug 24, 2007 | 09:00 AM
falkore24's Avatar
Default RE: WHEEL ALIGNMENT ?
Try that signature again. For some reason, I can't see the year, model and trim of your car.
Old Aug 24, 2007 | 12:06 PM
finch13's Avatar
No, alignment doesn't change ride height at all. Maybe your drivers side springs are starting to sag
Old Aug 25, 2007 | 10:48 PM
Super Eurobeat's Avatar
this is normal for every car, the drivers side to sag due to the drivers weight causing extra stress and fatigue. This also contributes to spring sag and damper wear at a more accelerated rate vs the passenger side, the only way to make sure this is fixed by going to a coilover adjustable ride height suspension.
Then you can have your car corner weighted so your car so its back to flat again.
You will have a pull to the left naturally because of this wear and tear on the car.
Old Aug 26, 2007 | 07:52 AM
Chaqui04's Avatar
Thanks for the advice.
Old Aug 26, 2007 | 12:42 PM
smaglik's Avatar
in my m3, the car sits a bit higher on the drivers side to account for the weight of my *** when i get in...
mtill58513
Sep 1, 2014 11:06 AM
lapper69
Sep 12, 2013 08:58 AM
creamystuffs
Oct 24, 2010 07:29 AM
sedgerton
Sep 12, 2007 07:25 PM
deserthonda
Sep 29, 2006 01:52 AM
