4 Lug to 5 lug Rotors
Old Apr 5, 2012 | 07:35 PM
drumdoctor's Avatar
Default 4 Lug to 5 lug Rotors
I have a 1996 Accord LX.
What do I need to convert the stock 4 lug rotors to 5 lug rotors?
Thank you.
Old Apr 5, 2012 | 08:44 PM
g22cd5's Avatar
Supper Moderator
Old Apr 5, 2012 | 09:11 PM
drumdoctor's Avatar
Default 4 Lug Rotors to 5 Lug Rotors
I was told that I need 6th generation rotors---yet you say I need 5th generation rotors.
Which is it?
So whether it is 5th or 6th generation, the rotors are a direct bolt on?
But you also said something about the brakes...
Do I need to do something to the brakes also when I switch the rotors?
Thank you.
Old Apr 5, 2012 | 09:27 PM
crispin's Avatar
yes you need to do something about the brakes, you must change them.
The write-up gives all the info you need.
Old Apr 5, 2012 | 09:37 PM
drumdoctor's Avatar
What write up?
I have missed something somewhere.
So my stock 1996 calipers will not work on the 5 lug rotors?
Why is that?
Aren't the rotors basically the same except for the number of lugs?
Thank you.
Old Apr 5, 2012 | 09:44 PM
crispin's Avatar
Originally Posted by drumdoctor
What write up?
Why is that?
Thank you.
The write up in the link provided by G22cd5
It gives the list of parts needed, quite a lot of parts
Old Apr 5, 2012 | 09:45 PM
crispin's Avatar
this is the list of parts needed
95+ Honda Accord V6/92+ Honda Prelude VTEC Front Calipers (1L, 1R)
23T Caliper Brackets** (2)
95-98 Honda Odyssey/95-97 Honda Accord V6 Front Knuckles* (1L, 1R)
95-98 Honda Odyssey Front Wheel Bearings (2)
95-98 Honda Odyssey Front Hubs (2)
98+ Acura ITR/97+ Honda Prelude Front Rotors(2)
97+ Honda Prelude Rear Hub/Bearing Assemblies (2)
98+ Acura ITR/98+ Honda Accord V6 Rear Rotors (2)
Rotor Screws (8)
20 lugnuts
Old Apr 5, 2012 | 09:46 PM
g22cd5's Avatar
Supper Moderator
go read the write up in that link I posted. All the info you need for this swap is there. and no it's not just as simple as the rotor. you need the 5 lug knuckle. ect ect ect
Old Apr 5, 2012 | 10:14 PM
drumdoctor's Avatar
How do I know if I have the correct knuckles?
This is my 1st Honda and I can't believe that it is this complicated and involves this many parts just to change from 4 lugs to 5...
Thanks for all the help.
HORSEPOWERJUNKIE2007
Sep 2, 2008 08:02 PM
jkellyre
May 15, 2007 07:39 PM
benjiaccord
Mar 20, 2007 10:21 PM
Tommy997
Jul 26, 2006 02:14 PM
deserthonda
May 12, 2006 04:06 AM
