5 lug rims on a 4 lug
Old Mar 23, 2009 | 11:51 PM
joelluv12's Avatar
Default 5 lug rims on a 4 lug
hi , i would like to know what is it that i need to do in order for me to use 5 lug rims on my 98 accord lx 4 lugs. thanks guys
Old Mar 24, 2009 | 12:02 AM
cjdm98's Avatar
highly don't recommend it but you can buy one of those ebay Hub adapters.Or, do a accord v6 5 lug conversion.plenty of how to's floating around the web.
Old Mar 24, 2009 | 08:00 AM
You'll need to convert your front hubs & rotors over to 5-lug, which is basically the same job as replacing the wheelbearings. Pressing the 4-lug hub out will most likely destroy the wheel bearing. New bearings, new hubs, new rotors.
Check the diameter & thickness of the rotor in some published specifications. If the V-6 uses bigger rotors, then you need new brake calipers as well.
Pretty much the same story at the rear, but you may need to do a rear-disk-brake conversion from V-6 parts. The 7th-gen Accord LX has drum brakes & 5-lug wheels, but I don't know if you can just install that hub & drum.
Lots of work... How bad do you want it?
Old Mar 24, 2009 | 10:07 PM
joelluv12's Avatar
i really wanted it so that i can put acura tl wheels on the, but i dont think its that important to me. , thanks guys
Old Mar 25, 2009 | 06:44 AM
Some day you're gonna need new wheelbearings anyway, so maybe just wait till then?
01Accord01
Dec 28, 2014 03:49 PM
KevinFelt
Dec 6, 2013 01:14 PM
HORSEPOWERJUNKIE2007
Sep 2, 2008 08:02 PM
jkellyre
May 15, 2007 07:39 PM
Tommy997
Jul 26, 2006 02:14 PM
