96 sedan wheel fitment help..
Old Jun 18, 2013 | 12:08 AM
rgr 96 monstro's Avatar
Default 96 sedan wheel fitment help..
I have a problem have my 96 sedan suspension kyb struts on eibach pro kit now I'm trying to put some xxr 531 17x9 with 25 offset.my question is will they stick out of so what will I need to do. Planning on 225/45/17 tire.thanks a lot
Old Jun 18, 2013 | 12:41 AM
Talking Hello Member
Help has arrived..click on link and check out the fitments..
Honda Accord Forum - Honda Accord Enthusiast Forums - Announcements in Forum : Tires & Wheels
Old Jun 18, 2013 | 06:56 AM
Thanks for the link did calculations but I'm still a bit confused I got inner clerance11.75 mm less outer position by 51.75mm diameter difference -0.01" (0.03%) can you better explain thanks
Old Jun 19, 2013 | 03:31 AM
hondafreak91c's Avatar
You are gonna need to do some work to fit those specs.
First off. You suspension won't be low enough to fit the wheels properly. With Pro-kits, the wheels will stick out quite a bit. You will need to drop the car around 2.5" or more to get enough natural camber to properly fit the wheels. So you will need a set of coilovers to lower the car that much.
Secondly.....225/45 tires are WAYYYYYYY too big. You will rub like crazy, especially up front. You are going to want to run a 215/40 (little bit of stretch) to not rub. Also, a 215/40 on a 17 inch wheel keeps the overall diameter very similar to stock wheels, so the speedometer will read accurately. a 225/45 would throw it off quite a bit.
In addition, you will need to get your fenders rolled for extra clearance and decreased rubbing.
Here is a friend's car with properly fitted 17x9 +25 Rota Grids.
Attached Thumbnails 96 sedan wheel fitment help..-255462_315749905189586_1201082034_n.jpg   96 sedan wheel fitment help..-255462_315749905189586_1201082034_n.jpg   96 sedan wheel fitment help..-255462_315749905189586_1201082034_n.jpg   96 sedan wheel fitment help..-255462_315749905189586_1201082034_n.jpg   96 sedan wheel fitment help..-255462_315749905189586_1201082034_n.jpg
96 sedan wheel fitment help..-255462_315749905189586_1201082034_n.jpg   96 sedan wheel fitment help..-255462_315749905189586_1201082034_n.jpg   96 sedan wheel fitment help..-255462_315749905189586_1201082034_n.jpg   96 sedan wheel fitment help..-255462_315749905189586_1201082034_n.jpg   96 sedan wheel fitment help..-387026_298867963470976_100800196_n.jpg
96 sedan wheel fitment help..-387026_298867963470976_100800196_n.jpg   96 sedan wheel fitment help..-166939_293162420708197_974066466_n.jpg   96 sedan wheel fitment help..-166939_293162420708197_974066466_n.jpg   96 sedan wheel fitment help..-387026_298867963470976_100800196_n.jpg   96 sedan wheel fitment help..-387026_298867963470976_100800196_n.jpg
96 sedan wheel fitment help..-387026_298867963470976_100800196_n.jpg   96 sedan wheel fitment help..-387026_298867963470976_100800196_n.jpg   96 sedan wheel fitment help..-166939_293162420708197_974066466_n.jpg   96 sedan wheel fitment help..-166939_293162420708197_974066466_n.jpg   96 sedan wheel fitment help..-166939_293162420708197_974066466_n.jpg
96 sedan wheel fitment help..-387026_298867963470976_100800196_n.jpg   96 sedan wheel fitment help..-387026_298867963470976_100800196_n.jpg   96 sedan wheel fitment help..-387026_298867963470976_100800196_n.jpg   96 sedan wheel fitment help..-387026_298867963470976_100800196_n.jpg   96 sedan wheel fitment help..-166939_293162420708197_974066466_n.jpg
96 sedan wheel fitment help..-166939_293162420708197_974066466_n.jpg   96 sedan wheel fitment help..-166939_293162420708197_974066466_n.jpg   96 sedan wheel fitment help..-166939_293162420708197_974066466_n.jpg   96 sedan wheel fitment help..-166939_293162420708197_974066466_n.jpg   96 sedan wheel fitment help..-387026_298867963470976_100800196_n.jpg
96 sedan wheel fitment help..-387026_298867963470976_100800196_n.jpg   96 sedan wheel fitment help..-166939_293162420708197_974066466_n.jpg   96 sedan wheel fitment help..-255462_315749905189586_1201082034_n.jpg   96 sedan wheel fitment help..-387026_298867963470976_100800196_n.jpg   96 sedan wheel fitment help..-166939_293162420708197_974066466_n.jpg
Old Jun 19, 2013 | 11:21 AM
Nice thanks a lot bro really helped out now last question does it bottom out. Front fenders are rolled already cause in the past I had 8 1/2 all around with a 2.5" drop
Old Jun 19, 2013 | 12:37 PM
If you have a good set of coilovers, it won't bottom out easily. They have increased spring rates to prevent that.
Old Jun 20, 2013 | 06:53 AM
Thanks a lot really helpful.
kenko95
Dec 6, 2008 01:29 PM
oldwhiteprelude
Nov 27, 2008 08:46 PM
calenatar
Oct 27, 2007 07:58 PM
Danny D
Sep 9, 2007 09:46 AM
daytonphotog
Jul 12, 2007 11:25 PM
