Autocross Tires?
Old Jun 3, 2010 | 01:56 AM
honda4AX's Avatar
Default Autocross Tires?
I apologize if this is not in the right section.
I have a 2004 Honda Accord LX 4cyl sedan (K24A4) that I use for autocross (you read that right ), and was wondering what would be a good track tire? The tires will be only be used for the track, and run on stock tires and steelies when i'm not at the track. So basically I need to be able to switch between the two when I' am at the track. I will be buying rim and tires. Money is not a big deciding factor, I just need more grip. That and destroying everyday tires is not fun. Thanks.
Side question: Is this worth it? :http://throwdownperformance.com/inde...roducts_id=748
Old Jun 3, 2010 | 07:09 AM
Welcome newbie! Yes this is the right section for tire questions, but I don't know the answer for you.
I don't think I'd like that e-throttle modifier thing. But first you should verify that you actually have a motorized throttle - I thought they weren't in for another year or 2. My 2003 LX did NOT have a motorized throttle.
Old Jun 3, 2010 | 11:42 PM
finch13's Avatar
What size wheels are you going to run? 17" is probably the best mix of low profile sidewalls and lightweight. I currently have 225/40/18 BFGoodrich g-Force T/A KDW tires on and they're great. Something with a low treadwear rating would be a good start.
Old Jun 3, 2010 | 11:43 PM
finch13's Avatar
Also, that e-throttle gizmo doesn't seem worth it. It's not going to get you more throttle, you're stuck between 0-100%; it just changes the sensitivity of the pedal.
Old Jun 3, 2010 | 11:52 PM
Both of you guys have the correct information for that member..
Good post men...
Old Jun 4, 2010 | 02:24 AM
honda4AX's Avatar
Thanks for the input guys and for a speedy reply. I do plan on running either a 16" or 17" rim (18" would be my max). Also, what about a wider* tire, whats the widest* I can get away with without modifcations if so possible. If anyone else has anymore ideas feel free to drop your comments. Thanks.
mihalis
Oct 20, 2011 11:11 AM
nponer
North East
Oct 9, 2009 02:13 PM
maro
Mar 10, 2007 12:15 AM
Mpwr
Jun 20, 2006 02:23 AM
technical_sedan93
Dec 11, 2004 09:41 AM
