brakes ???
Old Aug 21, 2007 | 12:12 PM
lockwoodconcrete
Default brakes ???
i have a 89 honda accord and i am having problems removing the rear drums...any hints..
how much wear can you have on your discs and drums befor you need to replace ?
Old Aug 21, 2007 | 10:48 PM
deserthonda's Avatar
Default RE: brakes ???
some time they get rusty ,, spray some wd40 on the inner part, get a hammer and tap on the outside edge of the drum while spinning it,, if it still does not come loose........get 2 ,8 mm bolts , long enough to reach the hub when you screw them in,, screw them in the drums , turn them evenly and the drum should beging to come out,, At times i have seen that the drums have such a big lip that when coming out it will take the shoes with it
But try this and let us know
alphaney
Feb 12, 2022 10:14 AM
phantomgrey92
Dec 22, 2015 10:24 PM
ZionsWrath
Jan 25, 2009 11:19 PM
Jcaleno
Apr 3, 2007 10:34 PM
thunder_x
Sep 27, 2006 11:00 PM
