Different Brand Brake Rotors.
Old Jul 17, 2006 | 08:31 AM
dj.fli4rt
Default Different Brand Brake Rotors.
I am planning to replace my stock rotors but ran into a situation. Brembo only makes rotors for the front of my car and i'm thinking of buying Powerslot ones to accomodate the rear. Will it cause any problem for my car since they're pretty much OEM fitted and both drilled slotted rotors-? I drive a 2003 accord coupe. Thanks in advance for any help.
Old Jul 18, 2006 | 01:55 PM
sir_nasty's Avatar
Default RE: Different Brand Brake Rotors.
as long as the grip pretty close to the same then it shouldn't be an issue... I don't think there will be enough of a difference between the two as long as you use the same brake pads front/rear...
Hondahonda
Mar 22, 2013 06:49 AM
sach4u1
Oct 10, 2010 03:12 PM
kriegz99
Aug 11, 2007 08:41 AM
benjiaccord
Mar 20, 2007 10:21 PM
deserthonda
May 12, 2006 04:06 AM
