does a soft or hard rubber compound help prevent rim damage?
Old Aug 5, 2007 | 09:37 PM
thunder_x's Avatar
Default does a soft or hard rubber compound help prevent rim damage?
like for example, when you are driving through bumps, would it be better to have a soft or hard tire compound so that your rim doesnt get bent
Old Aug 5, 2007 | 09:54 PM
smaglik's Avatar
Default RE: does a soft or hard rubber compound help prevent rim damage?
soft should absorb more...but just avoid the big bumps!
Old Aug 6, 2007 | 02:22 PM
sir_nasty's Avatar
The rubber compound isn't going to make nearly as big of a difference as how much sidewall you have. As far as compound goes I believe that as stated soft will absorb more, but that's the issue.... it will flex in further than a stiffer sidewall/rubber compound. so you'd feel it more with a hard rubber but have better protection (but not by much) Sidewall stiffness and depth are the two things that protect a rim, a rim almost never bends unless the rim itself is impacted by something, most tires can't generate enough energy/power to bend a rim without blowing the tire, then the tire blows and your rim gets hit by the object...
Old Aug 6, 2007 | 02:46 PM
thunder_x's Avatar
ahh, i get it now
JPodAccord
Jun 16, 2012 01:33 PM
eding00
Jul 27, 2009 07:11 AM
pyaarawala
Sep 14, 2007 12:57 PM
