front tires keep losing air
Old Sep 26, 2006 | 01:30 AM
thunder_x's Avatar
Default front tires keep losing air
i know that its the thing where you feed air into the tire from ( that long thing, forgot what its called...)
but yeah, any idea how to replace or fix it?
Old Sep 26, 2006 | 05:53 AM
Slusher's Avatar
Default RE: front tires keep losing air
Valve, and I think that I would just take it someplace to have it done. I'm pretty sure you have to remove the tire from the rim, pop the valve out and then put another one in. I'm not sure if you have to seal the valve into the rim, probably but I'm not sure. I don't think that it would be too expensive to have it done, maybe $15/wheel????
Old Sep 26, 2006 | 10:03 AM
mbo1985's Avatar
is the valve just bad or the whole valve stem?
if the valve stem is messed up, the tire needs to come off. If the valve is just broken, you can get a little valve remover tool and unscrew it (when the air is out of the tire of course) and swap in a good one.
Old Sep 26, 2006 | 12:33 PM
RTexasF's Avatar
Super Member
It's possible that the valve itself just isn't tight, it screws in and can work itself loose. Any auto parts store or bike shop will have the little tool to tighten/remove it.
Old Sep 26, 2006 | 06:20 PM
sir_nasty's Avatar
oddly enough I was just looking at recalls on honda's and this is one of them for a 94 accord.... I don't know what year/model you have but perhpas there is a recall on it.... search the net for "year accord recalls" and you should be able to find it... Not a for sure thing but it's worth a shot...
thunder_x
Apr 27, 2007 05:09 AM
maro
Mar 10, 2007 12:15 AM
DALAZ_68
Oct 1, 2006 08:18 AM
rickydelcid
Jul 26, 2006 08:46 AM
tomcal
May 10, 2006 04:10 PM
