I need to get educated
Old Oct 17, 2007 | 03:26 PM
willowtreexx's Avatar
Default I need to get educated
Alright guys so its time to help me out here. I am semi familiar with rims and tires but I am realizing that there is still alot more that i need to learn so i dont screw something up.
I have a 2001 honda Accord Ex V6 AT 4door.
I do know about aspect ratios and have decided i want to put on some nice looking rims. Im looking at 18's and in doing so i need to get tires to match the aspect ratio and those will b 225/45/18. Or am i completly wrong on that?
My future plans are to also get eibach lowering springs to maybe a drop of 1.5inches depending on real life.
so my question is what else do i need to know? I see in posts that people are talking about off sets and some other things along those lines. do i need to worry about that? and with a wider wheel and tire will it hit my fender when i lower it at all?
thanks guys i really appreciate it!
Old Oct 17, 2007 | 03:52 PM
falkore24's Avatar
Default RE: I need to get educated
Here's where you start:
http://www.tirerack.com/
http://www.miata.net/garage/tirecalcold.html
http://www.1010tires.com/WheelOffsetCalculator.asp
I'd look at 7.5" wide rims with a 45 offset for your car. Tough to say if they will rub on full turns, but they shouldn't. WheelBrokerAng may be able to help you better than I can. Glad to see that you want to learn first!
Old Oct 27, 2007 | 09:17 PM
Hi Member:
You would be better off with a 225/35/18 tire on those rims..you still may have to modify those fender wells to tuck them in-side..
[IMG]local://upfiles/22/981E1E0304A24324BFAAF8C82DC17D30.jpg[/IMG]
Old Oct 28, 2007 | 12:41 PM
BlkCurrantKord's Avatar
225/40 or 225/45 will fit, I'm assuming you arent dropped since you didn't mention it so you shouldn't have any rubbing issues given that you get the proper sized offset on the wheels.
Old Oct 30, 2007 | 11:16 PM
mdnky
A 225/35-18 would be way too small (diameter) on that car--about 5-6% slow.
225/40-18 (2% slow) and 215/40-18 (0.4% slow) would be the best options to keep everything right, with the 215 being the closest in diameter to the stock 205/65-15 tire. The 215 should also have less rolling resistance and offer slightly better fuel economy than the wider 225 series tire (every bit helps.) You can fin 215/40-18 Yokohama Avid W4s for about $118 each, so the price isn't too bad either. Same tire in 225 size is about $3 more...though there are quite a few more options out there for the 225/40-18 size than the 215/40-18.
Old Nov 12, 2007 | 09:57 PM
6up
So what tire combo did you go with for your snows?
tcheema
Apr 19, 2008 09:29 PM
isenegger
Jan 19, 2008 08:15 AM
GodMachine
Jul 11, 2006 10:59 AM
hellomoto
Apr 15, 2006 01:30 AM
houser995
Feb 17, 2006 10:56 PM
