New tires - Road force balancing
Old Mar 13, 2013 | 09:06 AM
jlemberg's Avatar
Default New tires - Road force balancing
Replaced original Dunlops on my 08 Accord LX(steel wheels). I am having a slight ride quality issue with the new ones, and have had the balance checked(not road force) 2x since I got them. I read an old post where it mentioned an occasional need to road force balance on these cars. I am having symptoms of the tires not really being in balance. Is there a reason for the need for a road force balance?
Old Mar 13, 2013 | 11:12 AM
If the tires are new, on old wheels, I'd just as soon suggest wheels might be bent? With all the protective safety shrouds to cover up the spinning wheel (on the balance-machine) the worker might not notice a bent wheel unless you ask him to actually look for it.
OTOH, you can check yourself by jacking up each corner of the car & spinning the wheel.
Some brake problems can mimic a wheel-balance problem. Also might be the inboard CV joints on the front axle, especially if it only happens under acceleration.
Old Mar 14, 2013 | 02:07 PM
jlemberg's Avatar
Maybe I'm just not used to the new tread...I don't know. It's only on rough road surfaces at 60mph +. I'll let them break in and re-balance in a few thousand miles i guess. It's just weird, like the tires dont want to balance.
Old Mar 18, 2013 | 08:10 AM
jlemberg's Avatar
Update. Using the 10% less than maximum pressure listed on the tire(39-40lbs) theory has greatly improved, if not eliminated the issue. I guess I'm outdated, as in the past I would have considered that to be too much.
Old Mar 18, 2013 | 08:56 AM
A better starting point would be the pressure on the car's sticker, which is probably 32psi.
Old Mar 18, 2013 | 10:51 AM
jlemberg's Avatar
I know right, 30psi, even pulled 8 or so pounds out after they installed them. 30 psi worked ok for the Dunlops.
Jared'Shin
Jul 10, 2013 12:06 PM
Old Honda Dude
Mar 10, 2011 09:18 PM
Antarctica
May 23, 2009 04:26 AM
Julian91
May 29, 2006 02:15 PM
igotjshoe
Jun 6, 2005 10:48 PM
