OEM rim size + tires that fit
Old Sep 11, 2009 | 04:10 PM
DavyDavon
Default OEM rim size + tires that fit
Hi guys I'm a bit lazy to search around the car specs.
I have an 05 EX-V6 6sp and i will keep the OEM 17" rims on it.
I am due for new tires very soon and I am very concerned about the sizes. I know that the whole diameter is 25.5. What i would like to know is what tire width can i use on the stock rims and in the same time what is the rim's width? 7"?
I am also wondering what are the gives and takes of having larger tires.
Thank you
David
Old Sep 14, 2009 | 10:22 AM
Rim width is very likely embossed into the rim SOMEWHERE. In between spokes? On the inside of a spoke?
Go to TireRack.com & look through the tire SPECS. For each tire size, they list the range of acceptable wheel width. That's ONE thing.
Then go through the motions of choosing a tire for you car. TireRack's site seems to have a pretty good database of what fits, for fender clearance & things like that.
Wider tires can improve cornering power, up to a point. If you keep going wider, it doesn't keep improving.
Wider tires are more expensive. Often the tires that are available in really wide sizes have a whole different character, sticky tires that wear out very quickly. That's not automatically because of the size, it's just one part of choosing a tire for YOUR needs.
Andrew James
Jun 21, 2021 10:58 AM
Zusue
Nov 17, 2009 03:24 PM
starbai
Aug 27, 2008 08:26 PM
maro
Mar 10, 2007 12:15 AM
dinzer
May 25, 2005 09:27 PM
