These rims
Old Jul 13, 2009 | 01:10 PM
hoffy101
Default These rims
what is the biggest sized rims you can put on a '94 accord? (in inches please)
Old Jul 13, 2009 | 01:20 PM
Sweagle02's Avatar
I'd say 17" or 18" max for the '94
Old Jul 13, 2009 | 03:14 PM
finch13's Avatar
18"..
Old Jul 14, 2009 | 11:02 AM
hoffy101
ok, now if I put those 18" on there, would I have to raise my car a bit or trim the finder? or would they just go on without extra work?
Old Jul 14, 2009 | 11:40 AM
dfaulkner's Avatar
ok, now if i put those 18" on there, would i have to raise my car a bit or trim the finder? Or would they just go on without extra work?
they will fit as long as the offset is correct, and since you'll be running a thinner tire, it will actually make your car look higher if it's not lowered.
Old Jul 14, 2009 | 02:17 PM
Sweagle02's Avatar
x2. If you don't mind the bigger wheel gap then go ahead and forget about a drop. The right offset, I believe about 41-45 (correct me if I'm wrong) and you'll be fine.
Old Jul 14, 2009 | 10:57 PM
hoffy101
Okay, pretty much what i want is this....the biggest rims I can get on my accord without having to worry about putting other things on or spending more money. I don't want to have to lower it because my rims were too big....I'm kind of on a budget, so anything extra such as the offset and lowering may not be necessary....
Old Jul 15, 2009 | 03:41 AM
finch13's Avatar
18x8.5 +45 is about as big and wide as you can go without running into any issues.
jrents88
Dec 20, 2008 12:36 PM
NoWeighJose
Jul 1, 2008 11:36 PM
j_man_honda
Jan 16, 2007 04:20 PM
BostonPuppyDawg
Jun 19, 2006 05:36 PM
Leonhartilly
Jan 20, 2006 08:26 PM
