These rims
they will fit as long as the offset is correct, and since you'll be running a thinner tire, it will actually make your car look higher if it's not lowered.
x2. If you don't mind the bigger wheel gap then go ahead and forget about a drop. The right offset, I believe about 41-45 (correct me if I'm wrong) and you'll be fine.
Okay, pretty much what i want is this....the biggest rims I can get on my accord without having to worry about putting other things on or spending more money. I don't want to have to lower it because my rims were too big....I'm kind of on a budget, so anything extra such as the offset and lowering may not be necessary....
