what offset should i get?
Old Mar 13, 2008 | 08:49 PM
yoshi86
Default what offset should i get?
hi, im driving a 2006 honda accord i4.. and im planning to get t1s rims by work wheels... 19x8.5 but im confused if a +48 offset will fit? need help asap tnx!!
Old Mar 17, 2008 | 12:10 PM
Default RE: what offset should i get?
Hi Yoshi86..
Here's some info for you to look at..
Your car can do a 19 X 8' with no problems and the ET and be between 40 to 55 offset..test fit for best fit when you turn your wheels..Tire size... 225/40/19 "
Here's a good looking wheel for you to look at
[IMG]local://upfiles/22/4993B52160894562BCB5DA7F5697D77C.jpg[/IMG]
Old Apr 13, 2008 | 09:02 PM
mojo's Avatar
What exactly is the offset?
And what would it be for a 96 4-door I-4?
Old Apr 16, 2008 | 12:29 AM
40to 42MM is the correct offset for your car...Offset is the location of the flat mounting surface of a wheel relative to the wheels centerline go to the top of this forum and read all about the links Iv'e put in for all members to read..
Good learning in there for all you members to read...
[IMG]local://upfiles/22/800EC88A77C04065B0E2B17A4E6FD162.jpg[/IMG]
willowtreexx
Jan 13, 2008 11:11 PM
thunder_x
Sep 5, 2007 07:31 PM
noboundaries6289
Apr 3, 2007 08:00 PM
thunder_x
Jan 15, 2007 09:05 PM
magicpenguins01
Jan 13, 2006 01:02 PM
