wheels and tires 18s?
Old May 11, 2017 | 04:54 PM
starrym's Avatar
Default wheels and tires 18s?
Hi I have a 2011 accord se and im looking into getting the (AR907 PVD) in 18s. also what tires can i go with without rub? Will it work?
Old May 11, 2017 | 08:02 PM
shipo's Avatar
Go to TireRack.com and plug your car in; everything will be revealed.
Old Mar 9, 2018 | 12:26 AM
Tuberculosis's Avatar
My concern with sites like that is that the wheel may fit, but how far does it stick out?
Most of those have much lower offsets. I fear that it won't work right.
Old Mar 9, 2018 | 07:47 AM
shipo's Avatar
If you put your year, make, and model in and select wheels and tires for that car, they will only show the ones which will fit.
Edit: I need to add one qualification to my previous statement; if you've lowered or otherwise modified the suspension to your car, then all bets are off.
Old Mar 9, 2018 | 09:39 AM
It'll fit perfectly without any rubbing or without sticking out half a mile from the fenders?
For instance, the car comes stock with 8Jx18ET55 wheels, and while I'll probably be looking at 18x8.5s, tirerack.com claims that a set of 9.5x20ET53s would fit both the front and the back just fine, but that doesn't sound right. Are you sure?
Thanks
starbai
Aug 27, 2008 08:26 PM
Jtweaz
Jan 8, 2008 02:29 AM
maro
Mar 10, 2007 12:15 AM
longneck8769
Apr 5, 2006 03:06 PM
ohiostatepimp22
Nov 21, 2005 08:15 PM
