Wierd Threadwear??
Old Mar 11, 2007 | 09:18 PM
Honda_Dude's Avatar
Default Wierd Threadwear??
on my dad's toyota truck, only one of the tire which is on the back is worn out. not worn out all over but only in the MIDDLE. does anyone know why that happened??
Old Mar 11, 2007 | 10:30 PM
Default RE: Wierd Threadwear??
Hi Honda_Dude;
How's your evening going..
The tires that wear out in the center is caused by over inflation of the tires..under inflated tires wear out on the edges of the tires..
Hope this answers your questions for you!
Old Mar 11, 2007 | 10:58 PM
Honda_Dude's Avatar
my evening is like anyother evening, how bout urs??
Over inflation, you mean, too much air?? does the alignment or the balance or tire rotation has anything to do with the problem. FYI, the tires are Firestone Destination LE. It says the treadwear is 480 or 460 (around that #) , isn't that suppose last long?
** this a pic of the tires.If you look close, there is 5 lines or track, watever you call it. Only the middle one (3rd section) is worn out, almost bold. only one tire.
[IMG]local://upfiles/7567/01340CEA5229452B9C2E5D15A49A2DBD.jpg[/IMG]
Old Mar 11, 2007 | 11:34 PM
smaglik's Avatar
its too much air.
Old Mar 14, 2007 | 03:48 PM
1stAccord_2ndHonda's Avatar
i concur... too much air... check the pressure...
Old Mar 14, 2007 | 09:18 PM
sir_nasty's Avatar
I'll concur on the too much air and expand on that answer.... if it were an alignment issue or camber issue it'd wear the inside or outside only, to little air and it's going to wear the outside evenly and no the middle.... Also, the reason it may only be one tire is because on those trucks it's not a locked differential so one tire is going to spin more frequently than the other, that tire is probably the one that recieves the power intially so it's going to wear first, that's also the reason that roatating your tires on older vehicles is more important than newer cars....
Old Mar 15, 2007 | 11:31 PM
Honda_Dude's Avatar
well its an 05 toyota tacoma
studentmechanic101
Apr 3, 2007 07:21 PM
skinwalker
Oct 15, 2006 04:22 AM
nixalot
Aug 10, 2006 04:54 AM
vi3tpride93
Jul 2, 2006 03:17 AM
shill1234
Oct 25, 2005 01:51 PM
