West AK, CA, NV, OR, UT, HI, WA, ID
96 Accord EX overheating
Old Sep 24, 2010 | 04:03 PM
maneater's Avatar
Default 96 Accord EX overheating
I have just replaced the timing belt, water pump, thermostat and I still have a problem. HELP!
Old Sep 24, 2010 | 04:21 PM
Most common reason for overheating after cooling system repair is air trapped in the system. Bleed air from bleed port near the thermostat housing while adding coolant until a steady stream of coolant emerges.
Other possible reasons in no particular order are 1) malfunctioning temp sensor/gauge 2) collapsed or inner carcase damage to radiator hose blocking flow, 3) blocked radiator (external debris, internal corrosion/scale, etc) preventing heat exchange, 4) leaking head gasket causing coolant to be displaced by combustion gas (loss of coolant).
Joshporsche
Jun 14, 2006 10:07 PM
Rizzie
May 28, 2006 12:04 AM
copa708
Apr 24, 2006 08:36 PM
mennerja
Jan 6, 2006 10:03 PM
erikhaha
Nov 20, 2005 02:48 AM
