Accord factory radio display Error E - Code instructions
#21
Look for this
In the glove box, on the same sticker as the serial number, is the five digit reset code for the radio.....at least it is on my 2010...just did it. Disconnect battery for 15 minutes to get rid of whatever code is displayed (1-9). after you hook battery back up there will be no error code number....just the text ERROR CODE...do nothing except enter those five digits...you should be done...put the radio on a rock station you Honda guru, you!
#23
Removing Positive Cable
Just FYI. This is comming from a certified Technician. You always put the Positive cable on FIRST AND OFF LAST. Everything else the gentleman said up top is correct. You only need to remove the negative cable for few mins.
#25
Off the bottom of what?
Dj Insanity
08-28-2009 04:20 PM
CasualObserver
12-14-2006 02:06 AM
