Accord factory radio display Error E - Code instructions
  #21
Old 05-23-2013, 10:57 PM
Default Look for this
In the glove box, on the same sticker as the serial number, is the five digit reset code for the radio.....at least it is on my 2010...just did it. Disconnect battery for 15 minutes to get rid of whatever code is displayed (1-9). after you hook battery back up there will be no error code number....just the text ERROR CODE...do nothing except enter those five digits...you should be done...put the radio on a rock station you Honda guru, you!
  #22
Old 06-08-2013, 05:53 AM
I need code number for honda Acord 2011 to the radio .I don't have that number .and what can I do if intered wrong number fo 4 times??
  #23
Old 10-11-2017, 06:02 PM
Default Removing Positive Cable
Just FYI. This is comming from a certified Technician. You always put the Positive cable on FIRST AND OFF LAST. Everything else the gentleman said up top is correct. You only need to remove the negative cable for few mins.
  #24
Old 10-11-2017, 06:05 PM
Hold the first and the last number on the presets "while holding" press the power button. Right down the two sets of numbers and call ur dealership. They will look it up for you.
  #25
Old 04-23-2022, 12:48 PM
Originally Posted by shadygrady
My 99 would not retrieve the serial # with the 1 & 6 preset button method but I did get a 7 digit number off the bottom with a mirror and a 9 digit number the same way.I believe the correct number is the 7 digit number.
Off the bottom of what?
BigShelby
12-18-2015 09:36 PM
Dj Insanity
08-28-2009 04:20 PM
RecMK5
02-13-2009 06:33 AM
my97lude
04-04-2007 01:09 AM
CasualObserver
12-14-2006 02:06 AM
Quick Reply: Accord factory radio display Error E - Code instructions
