Replaced my axle and boom: ABS light
Old Feb 15, 2010 | 12:24 AM
JP98's Avatar
Question Replaced my axle and boom: ABS light
I swapped my OEM axle today with an autozone axle. pt # 8097 and after driving for a minute or so, the abs light turns on. Has anyone ever ran into this problem before? I serchd but found nothing.
Would it be an issue with the abs sensor on the cv? Or is there some kind of bypass i can do? Thanks
I have a 4cyl, im sure it helps....
Old Feb 15, 2010 | 10:57 AM
That new axle DOES have the toothed ring for the wheel sensor? It needs that.
Did you manage to unplug the ABS sensor? The plug is inside the engine bay, pretty sure it's clipped to the outside of the shock tower. IIRC the plug is orange plastic.
Cut that wire while working? Leave a pile of metal shavings stuck to the sensor?
Old Feb 15, 2010 | 05:12 PM
JP98's Avatar
it does have the tooth on it, but i think the oem one had more... no extra metal chips are on there, its perfectly visible.
Old Feb 15, 2010 | 06:01 PM
It could be the teeth on the cv joint or the sensor.
I would just remove the wheel and clean any debris off of the sensor and clean the teeth on the cv joint. Make sure that you tightened the two bolts to the sensor (if you removed it when you replaced the CV joint).
It is possible that the wiring or sensor could have been damaged when you replaced the CV joint. Follow the sensor wire to its connector and unplug it. Test the resistance on the two pins. See if it is in the same range as the other sensor's resistance.
Old Feb 16, 2010 | 06:37 AM
The toothed ring MUST have the same number of teeth as the other. If you got the wrong axle, that could be it.
Get the ABS error code just in case the problem is unrelated to that.
Old Feb 28, 2010 | 01:07 PM
JP98's Avatar
it was the teeth on the remnd axle. i bought a new one and problem solved. too bad my tranny went sour after this. jut got a jdm one and its going from park to drive or everse is a bit delayed
JOE.G
Feb 3, 2019 07:42 AM
creeve4
Mar 18, 2010 02:50 PM
patrickz
Oct 14, 2008 09:56 PM
razcob
Nov 28, 2007 04:51 PM
nixalot
Jan 25, 2007 02:02 PM
