Sponsored by:
Sponsored by:
Bent Valves
Old 10-30-2007, 01:27 PM
Catcanski's Avatar
Default Bent Valves
Well, I had my 1997 V-6 Accord taken to the dealer after I attempted to do the timing belt with a friend (110,000 miles on it). They called and said that #1 cyl has 180 psi, #2 is at 60 psi and 3, 4, 5, and 6 are at 0 psi; basically bent valves. The dealer says it'll be expensive and not worth in on a 10 year old car. My question is, take it somewhere to have them fix it (and how much $) or me? How hard of a job is it? I've done head gaskets, heater cores, etc,but have never done valves. I don't want to bite off more than I can chew on this one. Any suggestions? Dave
Old 10-30-2007, 01:41 PM
00AccordLX5spd's Avatar
Registered User
Default RE: Bent Valves
It all depends ifbent valves are the only problem.
My question for you now is: What have you got to lose? You won't get much trying to sell it right now. You might as well try to fix it!
Old 10-30-2007, 02:08 PM
white95's Avatar
I went through the same thing this summer with my 4 cylinder. I removed the head and paid a machine shop about $400 to repair it. That was the el cheapo deal: clean, reseat, and replace damaged valves. If you go through with it, spend the extra money and have the seals and stems replaced.
You need toconsider the fact that you have two heads that need cleaned; my quote was just over $300 plus the cost of valves (I needed 7). So you're looking at about $600 + minimum5 valves @ $10-$15 a piece + seal/stem kit ($100?) + head gasket ($50?) = about $800to $825. If you bent one valve you probably bent two so double the valve cost = $850 to $875. To have a shop do the head removal/install I would guess at least $400 to $500 labor on top of that. So that comes to min. $1200or most likely$1375.
Short answer: junkyard motor. You have my sympathy.
Old 10-30-2007, 02:36 PM
Catcanski's Avatar
I just called a machine shop to do a head job, they quoted me $800, and then add $250 for a head gasket kit. I figure I'd do the rest of the work myself. I'm starting to think that the original $900 I was quoted for a timing belt replacement was a good deal.
Old 10-30-2007, 03:49 PM
Chiovnidca's Avatar
ORIGINAL: Catcanski
You can probaly pick up a good used engine for less than that. That's what we usually do.
Old 10-30-2007, 03:51 PM
I agree... pickup a used engine, that's what I would do.
Old 10-30-2007, 10:03 PM
smaglik's Avatar
trash it. new motor.
see if you can shoehorn an S54 in there.
Old 10-30-2007, 10:42 PM
white95's Avatar
ORIGINAL: Catcanski
I hear ya! I was quoted $700 to $750 for a complete timing belt service and I ended up spending about $650 + numerous hours under the car. Next time I'll take it to the shop and have them loosen the pulley bolt for me.[:@]
Old 10-31-2007, 10:53 AM
Pulley bolt should be easy if you can borrow a large compressor and a good impact gun. Not a cheepo ones.
HiMilesJ
12-23-2012 06:05 PM
redhardino
02-02-2008 08:35 PM
redsailtx
10-27-2007 10:41 PM
ooo5
08-27-2007 06:40 PM
Mpwr
05-12-2006 04:14 AM
Quick Reply: Bent Valves
