Sponsored by:
Sponsored by:
Confirmed Fix - Sunroof not automatically closing
Old 09-03-2013, 08:33 AM
bs13690's Avatar
Default Confirmed Fix - Sunroof not automatically closing
Hi,
I have a 2011 Honda Accord. The sunroof opens and closes but it doesn't automatically seat in the closed position. So, I have to kind of fiddle with it and look at the roof of the car to make sure it is fully closed. If I hold the close button too long, it moves into the "tilt" position.
Old 09-03-2013, 06:17 PM
Try resetting the moonroof control unit. If it doesn't work and you're under warranty, see the dealer.
1. Close driver’s door, leave it closed during the whole procedure.
2. Turn ignition to LOCK (0).
3. Press and hold the tilt switch, and turn ignition to ON (II).
4. Release the tilt switch, and turn ignition to LOCK (0).
5. Repeat steps 3 and 4 four times.
6. Check if the AUTO OPEN and AUTO CLOSE function still work. If they still work, the AUTO functions have not been cleared, go back to step 1. If AUTO functions have been cleared, go to step 7.
7. Press and hold the moonroof open switch for at least 3 additional seconds after the moonroof is fully opened.
8. Press and hold the moonroof close switch for at least 3 additional seconds after the moonrood is fully closed (tilted).
9. Confirm that the moonroof control unit is reset by using the moonroof AUTO OPEN and AUTO CLOSE function.
Old 09-04-2013, 07:55 PM
bs13690's Avatar
Thanks, boss, that worked like a champ. The moon/sun roof now closes normally.
Old 09-04-2013, 09:41 PM
Thanks for reporting back that it worked.
Joslinm
10-25-2013 10:43 AM
Samanthadd
09-20-2013 10:14 AM
Weebiecat
09-05-2013 11:54 AM
gberland
08-30-2013 02:09 PM
paulson524
08-10-2013 10:13 AM
Quick Reply: Confirmed Fix - Sunroof not automatically closing
