Confirmed Fix - Sunroof not automatically closing
Old Sep 3, 2013 | 08:33 AM
bs13690's Avatar
Default Confirmed Fix - Sunroof not automatically closing
Hi,
I have a 2011 Honda Accord. The sunroof opens and closes but it doesn't automatically seat in the closed position. So, I have to kind of fiddle with it and look at the roof of the car to make sure it is fully closed. If I hold the close button too long, it moves into the "tilt" position.
Old Sep 3, 2013 | 06:17 PM
Try resetting the moonroof control unit. If it doesn't work and you're under warranty, see the dealer.
1. Close driver’s door, leave it closed during the whole procedure.
2. Turn ignition to LOCK (0).
3. Press and hold the tilt switch, and turn ignition to ON (II).
4. Release the tilt switch, and turn ignition to LOCK (0).
5. Repeat steps 3 and 4 four times.
6. Check if the AUTO OPEN and AUTO CLOSE function still work. If they still work, the AUTO functions have not been cleared, go back to step 1. If AUTO functions have been cleared, go to step 7.
7. Press and hold the moonroof open switch for at least 3 additional seconds after the moonroof is fully opened.
8. Press and hold the moonroof close switch for at least 3 additional seconds after the moonrood is fully closed (tilted).
9. Confirm that the moonroof control unit is reset by using the moonroof AUTO OPEN and AUTO CLOSE function.
Old Sep 4, 2013 | 07:55 PM
bs13690's Avatar
Thanks, boss, that worked like a champ. The moon/sun roof now closes normally.
Old Sep 4, 2013 | 09:41 PM
Thanks for reporting back that it worked.
Joslinm
Oct 25, 2013 10:43 AM
Samanthadd
Sep 20, 2013 10:14 AM
Weebiecat
Sep 5, 2013 11:54 AM
gberland
Aug 30, 2013 02:09 PM
paulson524
Aug 10, 2013 10:13 AM
