Sponsored by:
Sponsored by:
Removing Wiper Arms?
Old 02-23-2008, 07:41 AM
JeffB's Avatar
Default Removing Wiper Arms?
I think due to ice, the wiper arms jumped a tooth. They bang badly at the bottom of the stroke. I could force them up a tooth while still attached but that's not a good idea. After loosening the nut, I tried all kinds of gentle prying methods to get the arm off but it didn't work. I don't want to force it or scrape up the plastic.
Either I'm missing something or it requires a puller to pop it loose. Any tricks out there to get them off?
THanks!
--Jeff
2004 Accord LX V6
Old 02-23-2008, 08:59 AM
Default RE: Removing Wiper Arms?
I've had to use a puller to break them loose, sometimes they can be pulled by hand. I don't think it's possible for the drive lug and wiper arm to "jump" position (too tight). More likely the gear drive is worn generating slop in the drive mechanism.
Old 02-23-2008, 02:05 PM
Wiggle it & pull on the side opposite the arm. I've always been able to get them off without a puller, but sometimes it takes a bit of wiggling.
Where the arm is attached to the shaft doesn't really have 'teeth'. The shaft is tapered & knurled, the arm has a smooth tapered hole. Reposition the arm & tighten the nut.
Old 02-27-2008, 10:14 AM
JeffB's Avatar
You were right on both points. Thanks for the tip!!
--Jeff
mahones
10-13-2008 08:24 AM
thunder_x
04-21-2007 05:28 PM
fireballer44
08-06-2006 06:00 PM
thunder_x
05-26-2006 01:52 AM
Evlampius
06-27-2005 08:07 PM
Quick Reply: Removing Wiper Arms?
