Removing Wiper Arms?
Old Feb 23, 2008 | 07:41 AM
JeffB's Avatar
Default Removing Wiper Arms?
I think due to ice, the wiper arms jumped a tooth. They bang badly at the bottom of the stroke. I could force them up a tooth while still attached but that's not a good idea. After loosening the nut, I tried all kinds of gentle prying methods to get the arm off but it didn't work. I don't want to force it or scrape up the plastic.
Either I'm missing something or it requires a puller to pop it loose. Any tricks out there to get them off?
THanks!
--Jeff
2004 Accord LX V6
Old Feb 23, 2008 | 08:59 AM
Default RE: Removing Wiper Arms?
I've had to use a puller to break them loose, sometimes they can be pulled by hand. I don't think it's possible for the drive lug and wiper arm to "jump" position (too tight). More likely the gear drive is worn generating slop in the drive mechanism.
Old Feb 23, 2008 | 02:05 PM
Wiggle it & pull on the side opposite the arm. I've always been able to get them off without a puller, but sometimes it takes a bit of wiggling.
Where the arm is attached to the shaft doesn't really have 'teeth'. The shaft is tapered & knurled, the arm has a smooth tapered hole. Reposition the arm & tighten the nut.
Old Feb 27, 2008 | 10:14 AM
JeffB's Avatar
You were right on both points. Thanks for the tip!!
--Jeff
mahones
Oct 13, 2008 08:24 AM
thunder_x
Apr 21, 2007 05:28 PM
fireballer44
Aug 6, 2006 06:00 PM
thunder_x
May 26, 2006 01:52 AM
Evlampius
Jun 27, 2005 08:07 PM
