Sponsored by:
Sponsored by:
How do I tell if a gasket needs to be replaced?
Old 07-11-2011, 05:31 AM
MessAround's Avatar
Almost A Senior Member
Default How do I tell if a gasket needs to be replaced?
When I took off the valve cover I realized that the valve cover gasket as well as all of the spark plug well seals appeared to be intact. All are in one piece, there is no cracking and they're all somewhat flexible.
Does this mean they're fine? Really not interested in wasting money to replace them if they're fine.
Old 07-11-2011, 08:14 AM
g22cd5's Avatar
Supper Moderator
you should be fine. But you might want to get some sealer (honda bond works the best)and seal the gasket back in its tracks(just a few beads hear and there will do the trick) to make sure it stays in its proper pace. Also try not to over tighten the VC it's 8.7 ft lbs to tq. her on down
accordhybridowner
10-27-2011 09:16 PM
cjkone978
06-30-2011 08:08 PM
jrcastro
04-21-2008 10:35 AM
BrooklynAccord
02-25-2008 11:48 AM
Quick Reply: How do I tell if a gasket needs to be replaced?
