Sponsored by:
Sponsored by:
not your average starting problem
Old 12-16-2009, 01:03 PM
Default not your average starting problem
Alright so my 95 lx has a starting issue. Its not every time, most of the times it starts fine. But every once and a while(esp when its sat for a week or more) it wont start. The lights all come on and everything, but the engine does nothing, doesnt crank or anything. have to sit there and keep returning the key over and over and over until it starts. I swapped the starter with one i know that works and the problem still persists.
any ideas?
Old 12-16-2009, 01:33 PM
finch13's Avatar
Probably the ignition switch. Dead batteries will usually make relays click because there isn't enough voltage to keep the relay magnitized to it's switch contact. Have you tried jiggling the key?
Old 12-16-2009, 07:22 PM
hondadude's Avatar
I'd say to go for a little dashdive and remove the lower cover off the steering column, then you can look at the solder connections on the back of the switch.
If you see one that is melted off or 'frosty' replace the switch.
CAUTION; the flat ribbon cable for the SRS is very touchy.
Don't even look at it sideways, much less jerk it around.
Old 12-16-2009, 09:16 PM
Thanks guys I'll look into the ignition switch tomorrow.
Old 12-16-2009, 10:24 PM
deserthonda's Avatar
AT or Manual tranny ??
if ignit switch looks good , i can help you diagnose the problem ,,, i need to know if AT or manual
manual has a starter relay,,
Old 12-16-2009, 11:08 PM
finch13's Avatar
It's a manual.
Old 12-17-2009, 07:49 AM
Finch is correct its a manual, going to look at the ignition switch a little later. Too bad its like 10 degrees out.
darkgreen18290
10-20-2010 02:22 AM
AceTheAce
05-08-2009 02:35 PM
itzztrick
03-14-2007 08:53 PM
marlon
01-26-2007 01:33 PM
thunder_x
04-16-2006 09:20 PM
Quick Reply: not your average starting problem
