Sponsored by:
Sponsored by:
Oil Leak under Pressure
Old 05-09-2012, 06:33 AM
rnewson's Avatar
Default Oil Leak under Pressure
I have a 2000 accord ex 190K and i have replaced the egr valve, valve cover gasket, thermostat and changed the oil. I noticed the other day that I have an oil leak only when the engine is on. No other time oil is leaking.
From what I can tell it looks as if it is leaking from the center of the car. No oil leak dye has been added.
What do you suggest?
Old 05-09-2012, 07:05 AM
crispin's Avatar
is it leaking from above the oil filter?
There is the oil pressure sensor there.
Old 05-09-2012, 12:05 PM
Suggest elevating car on ramps and getting under w/ engine idling to ID leak location. Oil pressure switch is a good possibility, but oil pan, or valve cover could also be the culprit.
Lovemy97HondaAccord
03-05-2014 06:04 PM
eduard
05-09-2013 12:11 AM
ChicagoBob123
11-06-2011 06:22 PM
piconrule
07-24-2009 02:38 PM
Karthigan
11-27-2006 02:55 PM
Quick Reply: Oil Leak under Pressure
