Sponsored by:
Sponsored by:
P0139 - Is it safe to drive?
Old 02-22-2012, 07:28 PM
ajsanantonio's Avatar
Default P0139 - Is it safe to drive?
I'm a girl and at least know to ask . The engine light just came on tonight (steady, not flashing) and AutoZone ran a check with the result being P0139. Is it OK for me to drive a day or two - no long distances - kids to school and to work and home?
Thanks in advance!
Old 02-22-2012, 07:42 PM
Yes, it is safe to drive. That is the code for the rear oxygen sensor.
If the light is not flashing, the car is still safe to drive.
Flashing check engine light usually would be caused by engine misfire, which would not be related to the oxygen sensor.
Your trouble code is not anything serious, just the part may need replacement.
Old 02-22-2012, 08:44 PM
That's a relief - thank you!
Old 02-22-2012, 09:04 PM
Also check your fuel tank's cap... it might not have been turned tightly enough. That could trigger this code, I think.
Old 02-22-2012, 09:14 PM
A loose gas cap would not trigger P0139.
Old 02-22-2012, 10:10 PM
Oh gotcha. Well, since people told me P0420/30 might be caused by a loose fuel cap or by a bad sensor... I thought the trigger conditions for that code would be very similar to the one for P0139. Oh well, at least the OP can't be mad over my incorrect but cost-less suggestion
Old 02-22-2012, 10:22 PM
Well, we don't want to cause unnecessary stress or worries for the OP. So, if the misinfo. wasn't corrected, then there is a "cost", maybe not monetary.
Old 02-23-2012, 06:46 AM
It's never a bad thing to make sure your gas cap is on properly, and it's not difficult to check.
Still, that shouldn't cause P0139 or P0420. It would cause P1456 "EVAP leak - tank".
NorthCountry
03-28-2015 02:58 PM
MessAround
09-24-2013 06:44 AM
powerslave
07-31-2012 03:09 PM
Nitehawk Girl
05-09-2012 02:54 PM
thedaveman89
01-12-2009 05:59 AM
Quick Reply: P0139 - Is it safe to drive?
