Sponsored by:
Sponsored by:
Reasons for slow cold start up
Old 09-06-2011, 04:42 PM
Tek310's Avatar
Default Reasons for slow cold start up
What are some possible reasons for it to take more revolutions of the starter to start the engine when cold.
Starter had to turn 4 times over the normal 2 this morning with it being in the 50s, and also could feel some very small stumbling vibrations.
I've cleaned egr passages, iacv, fitv, tb(both sides)
Weak battery?
Old 09-06-2011, 05:30 PM
Tek310's Avatar
Scratch battery. 12.8 volts
Old 09-06-2011, 07:07 PM
Not trying to split hairs here but more trying to get more info to help.
Is it really "slower" revs when the starter is on or is it the "same speed" but longer cranking? Don't get caught up in the numbers here as I'm making them up-another way of asking the same question, normally it cranks over at 300 RPM, but now it is cranking over at 125 RPM's.
Old 09-07-2011, 06:34 AM
Tek310's Avatar
Slower and more cranks
Old 09-07-2011, 08:25 AM
Still might be a weak battery. You probably measured voltage without any load.
Either have someplace like AutoZone test the battery, or measure it under load. Measure voltage at the battery posts, WHILE someone cranks the starter. How low does it drop?
brokenbones
11-02-2009 09:14 AM
testdrivin
11-18-2007 12:45 PM
nygamble
12
06-04-2006 11:16 PM
Quick Reply: Reasons for slow cold start up
