Reasons for slow cold start up
Old Sep 6, 2011 | 04:42 PM
Tek310's Avatar
Default Reasons for slow cold start up
What are some possible reasons for it to take more revolutions of the starter to start the engine when cold.
Starter had to turn 4 times over the normal 2 this morning with it being in the 50s, and also could feel some very small stumbling vibrations.
I've cleaned egr passages, iacv, fitv, tb(both sides)
Weak battery?
Old Sep 6, 2011 | 05:30 PM
Tek310's Avatar
Scratch battery. 12.8 volts
Old Sep 6, 2011 | 07:07 PM
Not trying to split hairs here but more trying to get more info to help.
Is it really "slower" revs when the starter is on or is it the "same speed" but longer cranking? Don't get caught up in the numbers here as I'm making them up-another way of asking the same question, normally it cranks over at 300 RPM, but now it is cranking over at 125 RPM's.
Old Sep 7, 2011 | 06:34 AM
Tek310's Avatar
Slower and more cranks
Old Sep 7, 2011 | 08:25 AM
Still might be a weak battery. You probably measured voltage without any load.
Either have someplace like AutoZone test the battery, or measure it under load. Measure voltage at the battery posts, WHILE someone cranks the starter. How low does it drop?
brokenbones
Nov 2, 2009 09:14 AM
testdrivin
Nov 18, 2007 12:45 PM
nygamble
12
Jun 4, 2006 11:16 PM
