Sponsored by:
Sponsored by:
strange noise in dash, 2005 accord
Old 10-24-2014, 01:09 AM
oldbeek's Avatar
Default strange noise in dash, 2005 accord
2005 accord,v6,auto, dual air system, Strange noise in area near speedometer. Sounds like a dry speedo cable or a hamster running on a wheel. Noise there when parked or driving down the road. Suggestions?
Old 10-24-2014, 08:14 AM
Sounds like infamous air mix control motor. It can make sounds such as scratching, growling, and clicking.
See following video for a DIY repair. Warning, the repair is a bit tedious, however a new part is $80-$100. Not hard to install. You can get under dash to locate noise and confirm fault. There are several related videos from froggy.
If you plan to DIY, suggest a emanual from automanualsource to guide your work.
Old 10-24-2014, 07:39 PM
oldbeek's Avatar
Thanks. What is the noise? The motor running constantly?
Old 10-25-2014, 07:31 AM
Motor feedback circuit gets dirty causing motor to hunt back/forth. Motor/gear defects in unit can also cause problems.
ndubg
02-26-2014 10:11 PM
briggsrepair
09-13-2013 10:17 AM
f_mehmood1982
02-10-2013 04:46 AM
honda1234
08-28-2009 12:53 PM
Drpepper
05-27-2007 07:36 AM
Quick Reply: strange noise in dash, 2005 accord
