Sponsored by:
Sponsored by:
water pump job plus oil in plugs
Old 12-28-2007, 03:51 AM
oma93's Avatar
Default water pump job plus oil in plugs
I've got the new water pump in, all new seals, new tensioners and I'm ready to do the belts. I did notice that one spark plug had oil in it. Just wanted your opinion should I replace the bottom seals now or just try new uppers and hope that fixes it? Do the lower seals go bad all that often? Thanks in advance!
Old 12-28-2007, 06:36 AM
drummer1279's Avatar
Default RE: water pump job plus oil in plugs
while you have that much of the engine broken down it would be a good idea to go ahead and do all that as well. better safe than sorry. those seals should be replaced every time you put on a new valve cover set along with the uppers, it all comes in a kit.
Old 12-28-2007, 08:46 AM
oma93's Avatar
That's what I thought as well. Thanks for the advice!
Old 12-28-2007, 09:33 AM
no problem
Lovemy97HondaAccord
03-05-2014 06:04 PM
PinkFloridaFlamingos
08-27-2011 08:08 AM
milano_6
09-27-2007 05:57 PM
solobaric6800w
01-10-2007 08:43 AM
Karthigan
11-27-2006 02:55 PM
Quick Reply: water pump job plus oil in plugs
