water pump job plus oil in plugs
I've got the new water pump in, all new seals, new tensioners and I'm ready to do the belts. I did notice that one spark plug had oil in it. Just wanted your opinion should I replace the bottom seals now or just try new uppers and hope that fixes it? Do the lower seals go bad all that often? Thanks in advance!
while you have that much of the engine broken down it would be a good idea to go ahead and do all that as well. better safe than sorry. those seals should be replaced every time you put on a new valve cover set along with the uppers, it all comes in a kit.
Lovemy97HondaAccord
Mar 5, 2014 06:04 PM
PinkFloridaFlamingos
Aug 27, 2011 08:08 AM
milano_6
Sep 27, 2007 05:57 PM
solobaric6800w
Jan 10, 2007 08:43 AM
Karthigan
Nov 27, 2006 02:55 PM
