*98-02 CHEAP* LED CONVERSION [cluster, clock, dome, maps, door, plate]
Old Dec 1, 2011 | 05:27 PM
  #41
azndude171's Avatar
will these work for a 2001 honda accord v6 sedan lx?
Old Dec 2, 2011 | 04:28 AM
  #42
matthew_ngkaiu's Avatar
Which light are you going to replace for your 2001 honda accord v6 sedan lx??
Old Dec 3, 2011 | 01:16 AM
  #43
Peli's Avatar
The '01 used 194/168 bulbs (wedge) for the courtesy (door), map and the trunk lights, and the dome light is a 31mm festoon bulb.
Pretty much if you pop off the cover and it looks like this
It's a 31mm festoon bulb
If it looks like this
It's a 168 or 194 wedge bulb (I have used them interchangably with no negative results so far)
Note: The size of festoon bulbs does fluctuate by about one mm between models, but I think most Accords are 31mm.
Old Dec 3, 2011 | 02:16 PM
  #44
azndude171's Avatar
thanks for the replies guys.
I was looking for changing the light on my cluster gauge. (Every single light in there.)
To: Peli:
I remember changing my tail light and its look like the 2nd picture.
So, I guess those are on the side of my door too?
Old Dec 3, 2011 | 02:23 PM
  #45
The best thing to do is not to guess, but to open up and see whats in those light slots..
Old Dec 3, 2011 | 06:39 PM
  #46
Peli's Avatar
To: Peli:
Honda lists your door lights as 168, so that's what I'd go with. It's very easy to pop off the cover and take a quick peek though, just to be sure
Old Dec 5, 2011 | 05:32 PM
  #47
azndude171's Avatar
Hi, Hondaaccordman, can you plz list the instruction on how to changes those light?
I try search it up, but no good outcome for me. I guess I'm just really bad at searching.
Old Dec 8, 2011 | 01:03 AM
  #48
Peli's Avatar
What is your model Accord? Most of them you can just use a small tipped flathead screwdriver to pop off the light cover and just pull the bulb out. Use a cloth to protect the plastic outside from being damaged. The bulb is a wedge so just pry it out. I recommend pulling the light fuse before you do so!
This is what mine looks like, and yours probably looks similar once you get the cover off. The two sets of prongs hold the bulb.
Old Dec 8, 2011 | 02:24 AM
  #49
Talking
Good post with picture Peli
He shouldn't have any questions after that picture post..but I bet he will
Old Dec 8, 2011 | 05:06 AM
  #50
azndude171's Avatar
Thanks Peli. Very nice of you. Appreciated!
