02 Accord 4dr Fender Replaced
Old Jun 10, 2010 | 12:10 AM
02_Accord_SE's Avatar
Default 02 Accord 4dr Fender Replaced
hello i am new here.. i have an 02 accord se 4dr and i need to repalce the front left fender... does anyone know where to find a diy here or perhaps another website?
Thanks for all the help.
Old Jun 10, 2010 | 11:03 AM
keep_hope_alive's Avatar
a Haynes manual is your best bet and will give you images for the below items:
1. Raise vehicle, support on jack stands and remove the front wheel.
2. remove front bumper cover
3. detach inner fenderwell screws and clips, then remove the inner fenderwell shield.
4. open the front door and remove the upper fender-to-body bolt.
5. remove the screwsa slong the bottom of the body, and pull away the plastic rocker panel cover to access teh lower fender-to-body bolt
6. remove the remaining fender mounting bolts
7. detach the fender. it's a good idea to have an assistant support the fender while it's being moved away from the vehicle to prevent damage to the surrounding body panels.
8. installation is the reverse of removal.
P51Joe
Jul 23, 2012 07:19 PM
DT98
Sep 15, 2009 01:24 AM
BrooklynAccord
Feb 25, 2008 11:48 AM
PJ_STYLES_95AccordEx
Oct 24, 2007 09:58 PM
deathman68
May 8, 2006 05:01 AM
