Can't get backseat out of my 92 accord
Old Mar 23, 2007 | 01:55 AM
Dannok
Default Can't get backseat out of my 92 accord
Hi,
I've been searching the web for days along with trying everything i can to get the back seat out of my 4dr accord. i cant seem to get it or any information whatsoever. Theres no clips like on most cars i've had. Once i get the bottom section out im assuming the rest wont be hard.. unless in this car i somehow take the top section out first???? I have no idea.
Please help me before i go insane!!!
Old Mar 23, 2007 | 12:17 PM
cheggie's Avatar
Default RE: Can't get backseat out of my 92 accord
It's not too hard. Use a 6" extension, 1/4" drive is easiest.To remove the seat back, fold the seat down, and remove two 12mm bolts in each lower corner of the seatback - where the hinges are. You may need to pull the seatback carpet back slightly to see them. Remove each side bolster by pushing down on the seat bottom at the base of the bolster, and remove a bolt with a 10mm head. These are the toughest to do. Pull the bolster up after removing the bolt.On the seat bottomyou'll see a bolt - it's not centered, but slightly to the driver's side of center. It's easiest to put a knee on the seat bottom to push it down, then take the bolt out. The seat bottom pivots at the forward edge of the seat and unclips. The back and side bolsters must be out before the seat bottom can come out.
pstoric
May 20, 2015 06:45 AM
jakfish
May 10, 2012 09:38 AM
ken59
Feb 28, 2012 09:22 AM
hookup11
Feb 21, 2012 07:13 PM
webvan
Sep 4, 2007 03:33 PM
