Headlight help!
Old Sep 18, 2008 | 06:45 PM
the727kid
Default Headlight help!
I am trying to install HIDs on a 2006 Accord. I have installed HIDs in 3 other cars no problem but this one seems to be difficult. I figured out how to access each bulb, but there seems to be 3 small screws holding in each bulb, what is the easiest way to remove these? It is not easy fitting a screw driver back there so does anyone have any tips?
Old Sep 18, 2008 | 06:46 PM
Tippman7641's Avatar
Default RE: Headlight help!
twist and pull.. i thought the same, but then i just turned them.. i forget which direction though
Old Sep 18, 2008 | 06:47 PM
the727kid
I tried twisting at first, but I didn't put much pressure, but it is a simple twist and turn like other cars?
Old Sep 18, 2008 | 08:57 PM
htekken's Avatar
assuming you have stock headlights and they are 9006 bulbs. yes you turn the bulb counter clockwise and pull out. if that doesnt budge, if you havent already, try disconnecting the plug from the bulb first, then twist.
Old Sep 19, 2008 | 08:32 AM
falkore24's Avatar
I know what you are talking about .... it helps some to loosen those screws a quarter turn so that you can remove the bulb easier .... as mentioned, the bulb comes out like every other car, but those screws can make it tough. A Z-driver can loosen them .... that's what I used.
Old Sep 22, 2008 | 09:48 PM
cbarron814's Avatar
yes z screw drivers can get in tight places and are the most easiest tools to use
mamtsberg
Mar 17, 2010 09:15 PM
Fez
Mar 10, 2007 05:01 AM
live2rice
Oct 20, 2006 03:14 AM
hondakidpr
Jul 13, 2006 04:43 AM
