Looking to replace
Old Jun 24, 2012 | 10:16 PM
94ex915's Avatar
Almost A Senior Member
Default Looking to replace
Alright im looking to replace the rear bumper lights (Not to sure what they are called) With something like this.
1994-1997 HONDA ACCORD EX LX CHROME REAR BUMPER LIGHTS SIGNAL SIDE MARKER LAMPS | eBay
When replacing these do I need to replace the bulbs as well?
Old Jun 24, 2012 | 10:47 PM
Depending on your State's DMV vehicle codes, it is possible a cop may write a citation if it didn't conform to a vehicle code regarding the light color with a clear lenses at certain points of the car. There are different color bulbs if that was the case.
Other than that, you could just use the bulb you have.
Old Jun 25, 2012 | 12:28 AM
94ex915's Avatar
Don't think I would get pulled over so I'm not to worried about that. But I don't like the amber color and was wondering if I kept the old bulb on will it still be an amber color.
Old Jun 25, 2012 | 12:42 AM
The original rear side marker lenses were red with a clear bulb inside. The stock bulb light color without the lenses is a little yellowish.
If you use the same bulb in a clear side marker, then the lighting would be a little yellowish.
Since you mention an amber color, is the lenses the original red lenses or is it some aftermarket replacement?
Old Jun 25, 2012 | 02:05 AM
94ex915's Avatar
Oh wow I got mixed up in which ones im asking about. No the rear ones are red so your saying the light output would be yellowish if I got the ones in the link?
I meant to put a link to the front ones. Those are amber in color. Would I have to switch the bulbs out for those?
Old Jun 25, 2012 | 08:23 AM
For the rear side markers, if you use the stock bulb with the clear lenses, the light output would be yellowish.
For the front bumper turn signal lenses, you don't need to switch the bulbs if you don't want to. When I had a 1995 Accord, I replaced the stock lenses with white front bumper lenses. (The lenses I got were a opaque diffused pattern instead of just clear.) I just used the stock bulbs. The replacement lenses I bought also came with two amber (orange color) bulbs which I didn't use. I don't know if other aftermarket lenses come with the bulbs anymore.
Old Jun 25, 2012 | 08:05 PM
94ex915's Avatar
Ya I think the ones I was looking at came with amber/yellow color bulbs. Thanks much for your help!!!
KISSfan1977
Jun 21, 2011 10:10 PM
03Sleeper
Jun 13, 2008 11:39 PM
Shocker
Aug 15, 2007 12:39 PM
crazielude
May 7, 2006 04:40 PM
toicy4ya
Oct 23, 2005 10:50 PM
