Smoking/Tinting Tail Lights
Old May 6, 2008 | 11:16 PM
  #31
finch13's Avatar
Default RE: Smoking/Tinting Tail Lights
ORIGINAL: 19Accord97
Do you guys think it would look stupid if I blacked out my corner pieces next to the headlights?
I've seen it done a lot of times, BUT the turn signal bulbs aren't very bright as it is and upgrading turn signals to LEDs would be a PITA.
EDIT: You could get the JDM blackhoused corners...
Old May 7, 2008 | 08:14 AM
  #32
falkore24's Avatar
Film tint is meant for the inside of the window.
Old May 7, 2008 | 09:16 AM
  #33
HustLa's Avatar
Is it bad to just use black paint instead of this night shade stuff? I mean th transparency won't bother me because I don't want to paint over everything. I want to try something like this image, but I'm not sure if I can just use paint or if I have to use the other thing.
Old May 11, 2008 | 04:27 PM
  #34
HustLa's Avatar
Size:  51.5 KBI ended up doing it haha.
Old May 11, 2008 | 04:31 PM
  #35
19Accord97
Looks nice!
What was the process you used?
Old May 11, 2008 | 04:36 PM
  #36
HustLa's Avatar
I removed the taillight. Used spray paint. 2 coats primer, 3 coats black paint, 2 coats of clear coat and let it dry about a day
Edit: I forgot to mention that I used clear red tape to put over the parts I didnt want painted and used a razor blade to shape it.
Old May 12, 2008 | 11:31 AM
  #37
donpisto's Avatar
I was never a fan of the long red piece on the coupe. I like whta you did, looks MUCH better IMO. I'll be spraying my tails once I get them. I'm also going to replace pretty much all the bulbs. Going to go with LED bulbs where I can.
As for the headlights, the projector lights I have, have a bit of blue for the circular part (like when you see BMW's from behind). My headlights are white, maybe a faint of yellow in there and I don't like that. I'd like for them to blend better. Perhaps a white/blue. I forgot where I saw it, but people recommended a certain type of bulb from Sylavnia. Is that what I should stick with or something else? If I should stick with the Sylvania, which type do I get? I've noticed there are their high performance bulbs and some other ones, so I'm not sure which one I would need.
Old May 12, 2008 | 11:59 AM
  #38
falkore24's Avatar
Just a heads up ..... LED's in the reverse lights look cool, but don't put out as much light ...... might want to consider sticking with bulbs there.
Old May 12, 2008 | 12:20 PM
  #39
finch13's Avatar
Sylvania makes Silverstar and Silverstar ULTRA bulbs that are a bit whiter and brighter than regular halogens. DDMTuning also makes a relatively cheap ($150) HID kit in a range of temperatures.
Old May 12, 2008 | 01:16 PM
  #40
donpisto's Avatar
ORIGINAL: falkore24
Hmmm, I would have thought they would put out more light. I was thinking about replacing all the tail light bulbs with LED's and also the front turn signal. In all cases would it be not as bright?
ORIGINAL: finch13
Thanks for the info. If I hadn't bought the headlights I have I probably would go with the HID kit. Just gotta get me some of the bulbs you mentioned tho.
